I think that the greatest advantage of using Maxwell Render 1.0 (even curent RC versions ) is the Maxwell Studio included inside the package, you can simply export to 3ds from archicad and import to M~R studio apply materials position the building , set the sun and voila, also the speed has increased significantly from beta its just those d*** bugs still a problemo,
i talk about M~Studio since i dont see archicad M~R addon comming in the near future (the current AC plugin doesnt work at all with any of alpha,beta or RC versions), so either you'll need to use 3D max or other Highend 3D soft. or simply import your AC exported .3ds file
o and one interesting thing about 3D max M~R plugin it includes import of .kml files from Keyhole or Google earth so now you dont have to be smart and know all the lattitudes and longtitudes of the spot you're renderin
the easy setup of the scene is the greatest thing of all especialy for exteriors, when you need to use interior lightning its a bit of pain since youll need to think and "construct" path of light inside the scene if you're using special photometric efects from light, i belive that in the near future there will be a huge Maxwell material and light models library for sharing between the users .... same as the vray community has.
happy new year to all
Gezim Radoniqi | Architect |
