Visualization
Have technical issues...need help fast!
Ok I have a few different problems: (AC10 1176 EDU on Macbook Pro)
1) When I try to do a simple test render (72dpi, 2"x2" window, all low quality settings), I either get an error that there is not enough memory to render (i have 32 GB left on my macbook pro so that doesnt make sense)
-or-
the whole program crashes.
2) Upon reopening the program, my site is gone in all 3d views, but is still there in all plan views...????...im sure i just have something turned off, but im still worried because it was there before the crash and now its not...
Any help ASAP would be great, this is due at 8am mon morning and i have to be out of town all weekend
Fixed the site problem...just made it again...still wont render though
dont know what was wrong...i just redid the trees and site (rather painstakingly) and everythings fine now...
It is easy for a site to get messed up (crossing lines, unresolvable corners, complex overlapping SEOs, etc.).
Sometimes I can find the problem, sometime I just rebuild the site. (I always keep copies of working site models and layout/contour lines just in case.)
