Help: General light is not showing in 3d rendering
I am using archicad 14 and i used the general light sources (light cone down) and when i render its not showing (the lighting) in the rendering why is that? please help and thanks
13 Replies 13
David Maudlin
Reem_92:
I think the problem is that the sphere shown in Untitled.gif is the extent (Light Stops) of the light source, so this needs to be increased.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
If the problem is the lights around the base of the unit, I would suggest lifting the lights slightly above the floor surface.
David Maudlin
On closer inspection of Untitled.gif, the lights are not spheres but look like cones, pointing away from the base.
Reem_92:
Post a screen shot of the dialog box for one of these lights, with the Light Settings area under Parameters expanded.
David
I looked at david's pictures and that what i wanted to do, i think the problem was the cone light, i replaced it with the circular one and it worked fine
thxxx alot everyone
