How can I export from AC9.0 to Epix File? (piranesi)
Is there any way to export a render created on AC, to epix file, for Piranesi?
I know it from Artlantis, but not from AC.
I hope someone help me.
Thanks
13 Replies 13
I was missing a lot of fun with these useful tools, for piranesi, now I´m going to enjoy much better AC and Piranesi.
Glad that you found the add-on via the INT or US version. Strange that the add-on did not show up in the Spanish version.
Did you try copying the Piranesi add-on from the English folder into the Spanish one to see if the Spanish version of AC would load it?
Have fun with the more direct route to Piranesi.
PS Note also that Piranesi can place 3D objects into a scene. So, for example, if it turns out you need another piece of furniture in a scene that you've already been working on, you can display the furniture in AC 3D, save as 3DS (or other Piranesi 3D-recognized format) ... and then insert the furniture as a 3D cutout with the montage tool in Piranesi - with the ability to scale, rotate, etc. to place it as desired in the scene... including shadow casting. I think it is still better to get things as close as possible in AC first ... but this is an interesting feature of Piranesi 4. (Be sure you have the 4.01 patch, by the way.)
Karl, Yes is strange why AC9.0 doesn´t have piranesi on spanish, I made what you propose me and it works, very well, if you see on the image attached, is on spanish.
For the other way you say how to place cutouts, from 3d objects, I haven´t upgrade Piranesi to 4, I hope next month do it.
Regards,
David Welsh
Could anyone send me this Piranesi Epix Plug-in in e-mail to [email protected] ?
I would like to use it but from Informatix I received the answer that it is only included in INT or EN version and I should contact Graphisoft...
Zole
