Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Too Long
How can I get a render like this
Hi all.
I would like to produce a render that looks like the below image. this image is a screenshot taken right before Archicad starts to render.
I like the shadow and muted tones of the image but I just cant work out how to produce a render in archicad that resembles this.
Any ideas?
AC26 AUS Full
3 Replies 3
Too Long
All good, worked it out.
AC26 AUS Full
If you just stop the render a bit after it starts rendering, this is the result you will get.
Graphic Override all materials to a grey/clayish colour?
then you can get the full size render with muted tones without stopping a render prematurely and having it pixelated to oblivion
