How do I cover an entire wall surface with a jpeg for mural?
Wall Art Object the size of wall?
Material Library & use jpeg as "new material" to be used to "paint" wall surface? ( this causes repeating pattern ).
3 Replies 3
You can set the size of the image in the material settings.
Yes, Thanks, but when I did this, the image does cover entire wall & is displayed in 3D View Window, but when I render it in ArchiCAD 14 the image does not appear...?
In your material's settings you have to click on the "Match with Internal Engine" button in the Lightworks Rendering Engine dropdown.
