How to apply arroway texture into archicad rendering?
I have problem when rendering in archicad not realistic due tile texture, how or can arroway texture apply into archicad rendering?? tq in advance
2 Replies 2
It is pretty easy to do using the arroway diffuse map (the one ending in d). Do you know how to edit AC materials? I could walk you through it but may be easier to look at the user manual or other tutorial.
FWIW, I've found some really nice tile textures at http://www.porcelanosa-usa.com/. I often end up speccing tile from them as well.
http://archicad-talk.graphisoft.com/viewtopic.php?p=204945
