on
2026-04-22
01:44 PM
- edited on
2026-04-22
03:19 PM
by
Aruzhan Ilaikova
When rendering interior scenes with Redshift in Archicad, ceiling lights may appear as black rectangles instead of evenly glowing panels. This issue is common in interiors with ceiling grids and diffused lighting panels and can make the visualization look artificial and distracting. This article describes how to hide the Area light object in the render and use a glowing surface instead, so the ceiling panels appear naturally lit while still contributing to the overall illumination.
Redshift is a GPU-accelerated rendering engine available in Archicad with a Full or Commercial license and an active Graphisoft Forward subscription. It is integrated through the Cineware by Maxon rendering engine, providing faster and more realistic renders directly from Archicad. Learn more about Redshift in this article.
When rendering interiors with Redshift, Area lights can sometimes appear as black rectangles in the final image. This happens when their visibility settings are not configured correctly, resulting in unrealistic and distracting artifacts in the render.
Before diving into the steps, let’s clarify the scene setup and the role of the Area light. Area Light is a type of light source used to simulate realistic lighting in interior renders. They act as light emitters and are often used to create soft, diffused lighting. They won’t visibly appear in the final render unless configured improperly.
1. Adjust Area Light Settings:
2. Create a New Surface with Luminance:
3. Apply the Surface to the Light Object:
This setup will make the light appear visible in your scene, eliminating the black areas while providing accurate illumination.
These techniques were originally shared by Community member @derekjackson. If you’d like to explore the original discussion, click here to read the full thread!
This article is part of the ‘Tip of the Month’ series on Graphisoft Insights, highlighting valuable community-driven solutions for modeling challenges. Try these methods in your next project and experience the difference in model quality and efficiency.
Redshift is a GPU-accelerated rendering engine available in Archicad with a Full or Commercial license and an active Graphisoft Forward subscription. It is integrated through the Cineware by Maxon rendering engine, providing faster and more realistic renders directly from Archicad. You can learn more in the Redshift for Archicad overview on Graphisoft’s website.
