RafaelMA
Indoor Lamps not casting light in Cinerender
I'm trying to render an Indoor Lamp Only scene, but none of my lamps are casting light. The only visible lights are of the lightbulbs themselves.
I tried adding an IES light and that one worked fine.
The non-IES lamps are turned on on the light settings.
Any thoughts about why that might be happening?
LAMPS NOT CASTING LIGHT
LAMPS ARE TURNED ON
IES LIGHT WORKING FINE
5 Replies 5
Hello RafaelMA,
Is it ya lamp you create ?
Did you try to put it into another model with other Cinerender parameters ?
Are you able to open this lamp to check its GDL script ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
mikas
Had some extra time today.
Tried the lamp object with AC22 - it worked ok, a lightened up interior was rendered by cinerender.
Tried it with AC 23 - that resulted a black interior render, just like yours.
I certainly am not sure about the cause, but it seems like a lamp bug or a render engine bug.
AC28, Rhino8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
With AC23 3 lights = 2 light spheres and one lamp "Floor Lamp 03" between
No black render 😕
Christophe - FRANCE
RafaelMA
EDIT:
Only IES lights are working, none of the other objects like spots or desk lamps are working.
Thanks anyway!
Christophe wrote:
No black render :/
mikas
Tried at home, and it works with AC 23 now too. (Yesterday I was at work.)
I don't know what is the difference between my setups causing this. I've got AC 23 Mac, 3003 INT Full in both my macs.
I tried different settings a little bit, and got some peculiarities to show up though.
