Dwight
LightWorks Quality Levels
Users will see dramatic differences in ray tracing between "Final" and "El Gordo Supremo" rendering qualities.
For instance, overlapping panes of glass become opaque in final.
This example shows the problem. Thje supreme quality has enough ray tracing to cope, but EG Supremo level takes about 4x as long.
How I coped with this emergency was to do an SEO on the second glass panel, knocking it out, but obscuring the result behind the blind since it lacks any glass quality as a void.
Dwight Atkinson
3 Replies 3
Dwight
with the seo.
saved the bacon this time!
Dwight Atkinson
HOW I CAN CHOOSE BETWEEN THESE TWO LEVELS IN ARCHICAD? ISN'T IT AVAILABLE?
LUIS CARLOS
Dwight
of course you can. see attached. Method: best - yields more rays traced than final so that overlapping glass will remain transparent.
Dwight Atkinson
