Lightworks Rendering Engine
I have ArchiCad 11 when creating 3-D w/ Lightworks Rendering Engines selecting Pictures the final result the background (which is nice sky with clouds) shows up black. The model in 3-D shows correct but I cannot fix the sky backgound to show the selected one.
Does anyone know what I am doing wrong?
Thanks,
3 Replies 3
Can you post an image of your lightworks settings?
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
Size: 1182, 924 Pixels. Resolution: 150 dpi. Keep proportion of 3D window is on.
Method: Final, Effects: Reflection on, Transparency on, Smoth surface on.
Shadow casting: by Lamb setting (I have tried the 3 options). Light Sources SUn on 90%, Ambient on 90%. Antialilasing: close to Best.
Class: Sun: Realistic sun, Foreground: Depth cue, background: Plain.
Background: Picture on: Sky_clouds_1.jpg Resolution: 72 dpi, Magnification: 100%. Show previes: Image on. Image Bightness: Bright.
Overexposure correction: I tried all of them.
This should be your problem. I haven't used lightworks much recently, but I believe this is what controls the background in the lightworks environment. The 'plain' default color is black, so that makes sense. Change plain to image or scaled image, select the image, etc. and that should do it.
Jared Banks, AIA
