Thursday
- last edited
yesterday
As you can see in the model appearance settings, there are four to six visualization options for applying surface textures and colors; while the resulting output is interesting, it would often be ideal to combine both surface textures and surface colors. To achieve a high level of graphic representation for documenting detailed information and optimizing presentation formats, one could introduce a condition within the Graphic Overrides or add a setting option that allows the surface display to override the standard settings used in sections or elevations.
Thursday
What new feature in 30 is this relating to?
If it is just a request, it should be in the main community forums.
yesterday
I have moved the topic into the Visualization forum.
