Learn more
Roopa A
Materials / Surfaces
How to change vectorial hatching under surfaces. By default it will show certain hatches, If we want other than that how to change it.
Roopa A S
1 Reply 1
In the surface settings dialogue (Options menu > Element Attributes > Surfaces) you will see a button about half-way down the dialogue that will allow you to change the vectorial fill.
This will change it for all elements using that fill.
If you want to change it only for some elements then you need to duplicate that surface, change the fill and use that new surface on your element.
