Visualization
Max Image Dimensions in Lightworks
Does anyone know if there is a way to increase the dimensions for the final rendering image in the LW engine? I've got a model that i'd like to render at around 70" tall at 150 dpi, but the rendering engine won't let me get larger than 26.99" at 150. If the dpi doubles to 300, then the final image decreases to 13.49...etc... Anyone have an idea how to get around this? Thanx.
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
1 REPLY 1
Dwight
4048x4048 pixels. max. no workaround.
you could carefully segment and reassemble adjacent renderings from the same viewpoint..... perhaps.... but I am just speculating.
wht are you planning to use for material textures? that resolution is pushing everything ArchiCAD has.
your signaure sez 8.1
Dwight Atkinson
