DrawingStudio wrote:
Questions below
OBJECT LIST:
The OBJECT list seems very large and the names are just a series of numbers (from number 1 to 240) (I wish they were the names of the materials I had selected in ArchiCAD).
The (Windows) ArchiCad 10 plug-in assigns the material names to objects, you could figure it out this way
1) How does one organize this list into groups?
Select items, right click (select group items)
2) Is there a way for MXStudio to import as a group based on the material one has selected [or maybe by layers (one could lable the layer w/ the name of the material used)]?
Not sure if Plug-in can do this.
3) And does MXStudio allow you to assign a material to the entire group and not each object individually?
Yes, select items, drag material onto highlighted items
CAMERA:
Manipulating the camera doesn't seem very intuitive either, not like ArchiCAD...it seems you have to type in numbers...am I missing something that makes moving the camera, changing its angle, tilt, etc. easier?
I am just learning this too.  There is a PDF in the Maxwell folder,  Page 39 describing use of the camera controls, creating multiple cameras, etc.
