‎2006-10-03
06:45 PM
‎2023-05-11
12:30 PM
Noemi Balogh
‎2008-04-08 09:50 PM
‎2008-04-08 10:07 PM
MVP wrote:Ah! That explains the speed of Maxwell! Even with lots of fertilizer, I've never been able to generate sufficient ivy in less that three months!
Nice use of the ivy generator.
‎2008-04-08 10:29 PM
Peter wrote:Textures are mostly arroway and the planting up on the roof is photoshoped, except the ivy.
The planting on the roof's great. Are they something found in Maxwell or are they Onyx trees. The shrubs have a nice sense of 'danglyness' and the ivy stuff has a nice 'climbyness' to it!![]()
I've got a feeling the girl at the front is stalking you. She must have run quickly to the back of the building while you weren't looking! Be careful, she looks dodgy!
Thomas wrote:You are right, the contrast is quite distinct. Only excuse I would have is that bigger windows let more light in and lighter background behind glass makes reflections stand less out.
Very nice! The only thing I miss is the sky reflections in the windows. Compare to the existing building to the right.
MVP wrote:People are 2D and 3D lowpoly and I wasn't satisfied with them neither but at the same time couldn't tell what was the biggest disturbance.
biggest issue i have is how bright your people look, other than that, those are some nice images. Congrats.
‎2008-04-09 09:45 AM
sinatropus wrote:.....where did you hear these rumours? Not that I wouldn't want one but there's been absolutely no mention of anything like this in the Fryrender forums, even though we've been asking for it.
........FryRender has some advantages but it hasn't got THE plugin. Rumors are it's planed. ..........
‎2008-04-09 12:06 PM
Bricklyne wrote:Sorry, my mistake. I misinterpreted it , actually it was in the list of a potential plugins for the future.sinatropus wrote:.....where did you hear these rumours? Not that I wouldn't want one but there's been absolutely no mention of anything like this in the Fryrender forums, even though we've been asking for it.
I always imagined that an ArchiCAD plugin would be a dead-end for them, since they decided that they are not going to port Fry over to Mac platform and ArchiCAD is a dual-platform software.
And it wouldn't make sense (to me anyway) for them to only develop a PC plugin and version and then to completely ignore the Mac version and users.
It would be great if it turned out that they were actually developing an ArchiCAD plugin, especially with their upcoming RC4 VR editor and technology to be released after version 1. It sounds exactly like the type of technology an architect could hugely benefit from in developing and even selling projects and ideas beyond still render images.
‎2008-04-10 04:48 AM
‎2008-04-13 10:49 PM
The settings are:
Render time 40 mins (obviously stopped early)
Max sampling 40
I still can't get grass to work either.What grass material are you having trouble with ?
‎2008-04-14 06:30 AM
‎2008-04-14 11:49 AM
rslt wrote:I'm afraid archicad is quite limited to make this kind of distributions, though it is possible to manually place grass planes (Drag a Multiple Copy on a mesh with gravity turned on) but without instancing and also you have to consider a rotation to have some randomness (depending from the camera position). And use a wall with thickness 0 because then you have only one or two polygons instead of 6. UV maps purpose would be that the grass texture would fit onto grass plane (small wall with 0 thickness) but you can achieve this by assigning texture size for the grass material same as the wall lenght and height to be used as grass plane.
Hi MVP
Thanks for the advice with the settings.
The grass I'm having trouble with is the mxm by thxraph with this tutorial
http://www.maxwellrender.com/tutorials/grass_tutorial.pdf
1. It says 'beign by making a simple plane' - I tried it with a wall object that I made very thin (about 2mm),
2. then make a planar UV map, I have no idea what this is.
3. Copy and paste the plane (as per instructions), he ended up with 4260 planes per meter squared. Well, I tried it in Archicad (to be rendered in Maxwell) and the outcome was a very 'patterned' patch of green that did not look like grass. I deleted it so unfortunately I can't show you.
Archicad was starting to have trouble with this many 'walls' and really slowed down and this was only for 1 m2.
I would like to have the grass that can be seen on the pics of that tutorial. Looks good enough to roll in. Tee hee hee.
Any help would be appreciated.
‎2008-04-15 04:55 AM
