‎2006-10-03
06:45 PM
‎2023-05-11
12:30 PM
Noemi Balogh
‎2008-04-15 05:55 AM
‎2008-04-15 06:40 AM
‎2008-04-15 12:20 PM
rslt wrote:Not bad. But with complex and heavy geometry the 3D grass may just be little do much. In archicad the grass is just static mass. In other 3D packages with basic knowledge you can define presets that assigned to any mesh can automatically generate grass plane instances that more or less face the camera. At least I think so. Though it needs studio at the end to merge mxs-s from archicad and the grass from the 3D software.
Thanks to the advice I got, here is the first example of grass using the above mentioned mxm.
It rendered for 20 mins and even though it needs more work I'm quite happy with it. I left the rough ends to show the construction method.
It really does slow the computer down, this took about 5 mins to start rendering, there are 8386 walls with a thickness of 0 and height of 60mm and it covers a 10mx10m area.
One problem is when copying, the gravity selection doesn't work and doesn't carry over from the original object so I only have it working on flat surfaces.
MVP: If this is not a good material to be using for grass do you have a recommendation. I Photoshop grass but would like to get away from it, if I can.
http://i23.photobucket.com/albums/b367/rslt/Illustrations/grass.jpg
‎2008-04-16 04:04 AM
‎2008-04-16 04:20 AM
‎2008-04-16 03:38 PM
MaX_MaD wrote:Very nice! Hard to tell if you already have but try to avoid pure white because it's hardly ever exists in the real world, it flattens the image and generates more noise in maxwell. Paper white is something like RGB 220,220,220 if I recall correctly.
W.I.P
My first effort with a Archicad / Maxwell workflow.
I have been using Archicad for about 10 weeks now and I'm slowly getting it? Maxwell is new to me also and I kinda like the results but I'm finding it hard to get a clean internal image? Even leaving it over night I still find the results grainy, although external renders seem to come clean after a few hours..
Although I'm new to Archicad, I have been using AutoCAD and 3DSMax/VRay for many years.. So I am familiar with modeling, texturing, lighting & rendering.... sort of
‎2008-04-17 12:43 AM
‎2008-04-17 06:32 PM
‎2008-04-18 05:44 AM
‎2008-04-22 02:58 AM
