Learn more
Maxwell material expert needed...
Can someone tell or explain how to make a high quality material out of this texture: http://www.lusica.dk/walltexture.jpg ? I need to know how to make a diffuse- and bumpmap for it.
Ps: Im using Photoshop CS2
Thanks.
7 Replies 7
Hi turbo2000,
I'm far away from being MR material expert, but here is what I can tell you.
1. Diffuse map (colour) is the one you already have.
2. Bump map (grayscale) - defines material surface irregularities - white areas means more bump.
To make such map you need to simply convert diffuse map to grayscale
3. Specular map (grayscale) - defines reflective areas of material's surface, more white means more glossy. To make such map you can simply use bump map you already created and alter areas you want to be more reflective using levels control. It also should be grayscale.
4. Roughness map (grayscale) Usually it is inverted Specular map since what is glossy can't be rough same time.
IMPORTANT!: All the maps you want to use need to be RGB since MR will not work with grayscale maps (yet).
I strongly suggest to read MR manual first since there is a lot of info about proper approach in making MR materials.
BTW, your map is not seamless.
HTH, below is my quick try.
Rafal SLEK
How long was rendering time for such preview?
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD Collaborate
Around 45min, SL 12'ish, but I run this in the background during some other render, so it's not conclusive.
Usually 10-15min, SL 8-10 is more than enough for preview.
hi tigr thanks for helping! can you explain how you did the maps or even better make them so i know how they should look? I have made a tile-able texture here http://www.lusica.dk/Mursten-diffuse.jpg wich i would like to make bump and roughness maps for. Any help is appreciated
Sure I could just send you the maps but I think you'll benefit more if you try to do it yourself. It is 5 min job and next time you will need no help.
I have no CG background, I'm rather hobbyst so my approach might be wrong but still, it works great in everyday archiviz and only that matters.
Quick intro:
For making 99% of architectural materials those three maps (Diffuse, Bump, Specular/Roughness) are all you need. Sometimes it is enough to place only Diffuse map in every slot (this is how we do LW's materials) but it would be a shame to have such advanced renderer and not use it potential.
So why to make 3 different maps for one material? So you can control every aspect of your material separately.
1. Diffuse map - colour map of material. Make sure it is seamless and does not have any noticable shadows (like 90% of free textures have) Otherwise it will look fake if the lighting direction/power won't match the one in the map.
2. Bump map - grayscale version of Diffuse map. More gradients = stronger bump. To do such a map you need to go to:
Image -> Mode -> Lab Colour -> Grayscale -> RGB
Now you can use PS tools to clean some areas and alter others. Here the most bright should be the brick face and the darkest - mortar.
3. Specular / Roughness map - altered version of Bump map. More white = more specular. Now it is up to you what areas and how much reflective you need'em to be. Usually I do this:
Ctrl+L (levels) -> move left slider a bit to the right / move right slider a bit to the left -> judge the preview. This will add more contrast to the map and alter the reflective areas of the map. Roughness map is usually inverted version of a Specular map, so you don't even need to make one, Maxwell has such option on the fly.
Hope that was clear enough. Have fun.
Thank you for your time tigr! i have been experimenting with it, and now my photos look very nice!
Glad I could help. Don't hesitate to post your results, and I will get myself a beer. Cheers
