Learn more
Missing textures in 3D window
3D window in Open GLmode does not show jpg- textures! This is a real frustration to me because I can no longer use AC directly in client meetings etc.
What is visible are the vectorial hatchings and some textures based on Tiffs. But most materials are created on jpgs, and I really miss them!
The computer is brand new - an Acer Aspire 7745G with Intel core i7-processor / ATI Mobility Radeon 5850 card - with updated drivers. Operation system is Windows 7 Home Premium, 64. I use ArchiCad14.
Open GL is set to show textures.
I have reinstalled ArchiCad a number of times, but the problem persists.
Does anyone know this problem and a possible solution???
Arne I :(M
5 Replies 5
Material of the Open GL must match that of the Internal Engine.
Check your 3D window settings.
Make sure the textures are turned on for OpenGL.
Thank you, andro55! However I am still stuck with the problem. Material Settings dialogue simply don´t show or take in ANY jpeg texture, only tiffs or pngs.javascript:emoticon(':evil:')
Arne
They already were turned on for Open GL. Sorry I did not mention that!
Arne
Try resetting the Texture using the " Texture Resetting Button" available on the info box of the selected object.
