Visualization
Model in Archicad ... Render in Mentalray
Model in Archicad .. Render in Mentalray
2 REPLIES 2
Hey,nice effort!
I think that you have some light-leaks near the roof and where the wall meets the floor.
Also the light in the lamp shade cuts off quite sharp,unless you want this to happen maybe you should consider using a spherical light rather than a plane.
Cheers!
Ya thank you .. I just done a render test .. I will take down your points and make it perfect in next render . thanks
