Moire effect in AC
Hi, i tried to render the enclosed picture with AC and LW-engine. The walls are covered with a shader from the standard AC lib. How can i remove the moire effect wiht LW-engine in AC.
cu
Per
Dwight
[In Dean Martin voice]
"When the moon hits your eye like a big pizza pie… thats moire."
Can't fix it with ArchiCAD.
Make a larger rendering - say 3x - and if necessary, reduce the size in Photoshop using Bicubic Sharper Resampling.
Dwight Atkinson
