mike_linespire
Native ArchiCAD AI Visualization Plugin - Seeking Feedback
Hey everyone,
I've built an AI archviz addon for ArchiCAD that is using the latest Google models. As primarily a building designer, I wanted an addon that streamlined creating the image directly in ArchiCAD and placing it on the coversheet layout for our projects without needing to export/import.
I've played around with these AI models from the start and always been disappointed that whilst they were impressive, they weren't accurate enough to share with clients (missing windows, roofline changes, wrong materials). The latest models from Google are the first time I've felt they are producing client ready images (9 times out of 10!).
I'd love some feedback on the tool so I've setup a free trial that includes 5 image generations (reach out and I can top you up with a couple of extras if you need them). I'm going to get a macOS version going as soon as I can too.
There is a before/after slider on the website where you can see how accurate the AI model is at matching the geometry of the ArchiCAD model
18 Replies 18
PB
Now that my curiosity is piqued, I've had a look through the current Enscape & Twinmotion websites. They are both adopting AI within their products. Nothing to see yet for Twinmotion and the Enscape AI generated landscapes look too "Midjourney" for my taste...again, not sure how consistency works across different views/renders for the AI generated input.
AC30. Twinmotion. M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 27 Golden Gate
mike_linespire
Hey PB,
I think D5 are probably doing the most interesting AI tools at the moment. Their latest release can generate 3D assets from reference photos: https://youtu.be/Z3c7lDY98oY?si=A13Hxxgx4nDD0iJO&t=112
I would LOVE to be able to do something like this with Archicad GDL objects and maybe it will be possible in the future.
I know what you mean about the "midjourney" look! Google really raised the bar with Gemini 3 Pro (particularly for archviz) but I'm sure the other models will catch up.
Thanks
PB
Thanks Mike.
Yes, D5 shows the way forward - sadly, Windows only…
Aaron Bourgoin
I recall when D5 launched, the developers explained that while they were interested in supporting the Mac platform they wouldn't until Apple. hardware was strong enough. I wonder what they think now.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
mike_linespire
Hey Everyone,
Just an update to let you know the the macOS version is ready and up on the website (www.linespirereflect.com) if you'd like to give it a try. Took a fair bit longer than I thought to get a Apple Developer account so I could publish it. Also I've only been able to test this on a Intel-Macbook but it should be fine with the new Apple Silicone as well. Let me know if you have any issues.
In the mean-time I've also added a few new features to try:
-Before/After slider directly in the add-on so you can verify the accuracy of the produced image
-4k Upscale
-Updated the place on layout to work more intuitively
-Reference Image - you can upload a reference image that the AI model can use to copy lighting/materials/image style.
A couple of known issues:
-When using a reference image, the model can get confused and produce an amalgamation of your archicad view and the reference image rather than just copying the style/mood etc - Changing your archicad model to linework or whitemodel can help avoid this.
-When using the reference image, the final render will match the aspect ratio of the reference image instead of the archicad view. I'm working on a fix for this now.
A massive thank-you to everyone that has tried it out and provided feedback. My next goals are to add an editing workflow for making small changes to the images after they are produced and to overhaul the UI to be more intuitive.
If anyone has any other features that like to see, I'd love to hear about it.
All the best!
Michael
rkres
thats great, cant wait to try the new features out
PB
Many thanks for the heads-up: I'll give it a try this week...looking forward to seeing how it works...
marcoariveross
The creators of D5 were referring to the video card. They, like many others, take better advantage of ray tracing or patch tracing with NVIDIA's CUDA technology, and Apple doesn't use that technology (at least that's what I knew). AMD cards are cheaper and excellent graphics cards, but I think their technology still isn't quite up to par.
BIM Manager Pavimaq
Lima-Perú
Archicad 29-Windows 11-64Gb RAM
mike_linespire
[Moderator: The post contains advertisement for a commercial product.]
Hey everyone!
Another update on Linespire Reflect. Version 1.1 is out now, and it’s easily the biggest update since launch. A lot of this came directly from the discussion in this thread and emails from you guys, so thank you.
(new UI - includes render history and new tabs for setting up, editing and then animating) 
Back in February I mentioned that a UI overhaul and an editing workflow were next on the list. Here is where things have landed, along with a few major additions to what the plugin can actually read from Archicad:
  • 2D Views (Plans, Elevations & Sections): Reflect isn't limited to the 3D window anymore. You can now render floor plans, sections, elevations, and interior elevations directly. I’ve built in a few starting presets (like Brochure Plan, Site Plan, and Rendered Joinery Elevation), and you can tweak those or save your own.
  • Whole Layouts & Sheet Consistency: You can now capture an entire layout sheet, pick which drawings on the sheet you want to process, and render them all together in one pass. @PB and @rkres, this is a step toward the cross-view consistency you both asked about earlier - because the drawings are processed together, the AI keeps materials cohesive across the whole sheet. (Separate 3D camera views are still the tough nut to crack, though!). It can drop the results onto a new "Rendered" copy of your layout, or layer them cleanly over/under your existing linework.
  • Touch-Up Brush (Beta): You can now paint over a specific area, type what you want changed, and only regenerate that spot. Right now it’s best for small fixes—like scrubbing out a random object or removing stray text - plus the before/after slider now directly compares your edits.
  • Archicad 30 Support: Now running on AC 30 for both Windows and Mac (alongside 23–29 on Windows and 26–29 on Mac), plus a fix for an occasional crash on exit.
A couple of known issues to be upfront about:
  • The new Touch-Up brush still struggles with large, continuous surfaces, like trying to swap the material on a whole wall or a soffit. The edge blending isn't quite reliable enough for that yet, so a whole-image prompt edit still works better for big material swaps.
  • On very wide-angle views, the AI will still occasionally try to shift the camera framing - I've added a "Prioritise Camera Angle" that will mitigate this but gives the AI less freedom which can hurt the image quality.
Where my head is at for the next versions: A huge chunk of your feedback has been around editing the output once you have a render you mostly like, and that’s my main focus going forward. I’m currently testing more "Photoshop-style" selection and masking tools. The goal is to make it much easier to rein in AI hallucinations when it goes rogue on a detail, or to quickly update a specific part of a render after client feedback or a design change without having to re-roll the whole image.
I’ve put together a proper write-up with visual before/after examples here:https://www.linespirereflect.com/blog/linespire-reflect-1-1
(And if you just want to poke around without installing anything in Archicad, I also added a free sample project you can test directly in the browser: https://www.linespirereflect.com/dashboard/render).
As always, I'd love to hear what works and what breaks, especially on the new 2D plan and layout workflows! I've added a 👍👎 system directly into the addon so you can let me know what's working. It also gives the option to send your source image, prompt and output in an email to [email protected] if you want some direct feedback from me.
For those of you testing AI in practice (whether in Reflect, or if you've been trying out Graphisoft's new built-in visualizer in v30 - I'm on a perpetual licence myself so I haven't been able to take it for a spin yet): what’s the #1 edit or fix you find yourself needing to make after showing a first pass to a client? Knowing where the biggest friction is will help me figure out which editing tools to prioritize first.
All the best,
Michael
