Iām grateful to Rashid for sending me his model as weāve all had a good look at his fine effort in Cinema to render the ArchiCAD model. In particular, since I donāt do this kind of design work, I need models from others to prepare my lessons. Still looking for a cute middle-sized commercial building with lots of glass. Help!! Free rendering for the right project!!!
Hereās what I did with it:
1: sun object : five suns at 40, golden yellow.
2: skylite at 60, light blue ā see how it fills the shadows with cool color ???
3: ambient 25% - to compensate for a flaw in lightworks where shadows in white areas go suddenly to black ā the soffits in this case. Still not happy. Will make undersoffit material glow in next try.
4: Onyx trees instead of the lowpoly Cinema trees ā no good in ArchiCAD, anyway. I am an advocate of dark uninteresting foliage that doesnāt make a splash. Silly flower from archaic Medley library just for example.
5: took the saturation down on most materials.
6: Enhanced the depth mapping on the bricks and stone. maybe too much. Depends on the spec. How Rustic? Better than shiny flat Cinema approach.
7: MOST IMPORTANT: Stood a windo lite to shine into the front door alcove.
8: Goofed on foliage perforations ā canāt make pattern and transparent in LightWorks ā used too-coarse pattern for holes to simulate translucency. Better luck next time.
9: Decided brown roof was softer than dark grey. Do not send taste police after me.
10: Made windo blinds warm grey to counteract nasty moirƩ pattern. The moon hit my eye.
11: Note LightWorks glass more lively than Cinemaā¦
About three hours work if you donāt consider rendering time ā this is the kind of work I do ā ArchiCAD rendering is not automatic - thereās always tweaking.
Dwight Atkinson
