Visualization
New Render
Original Topic..
http://archicad-talk.graphisoft.com/viewtopic.php?p=21769&highlight=#21769
Final.. well almost final.. Dwight I know some dirt and Post effects would help but I have 4 fewer arms than others and only 24 hours per day to work. Forgot to rotate driveway pillars!
22 REPLIES 22
Dwight
I found this rendering on a website devoted to ancient underwater myths.
Interesting how the guy used the repeat of the grass texture to look like freshmown lawn and it must be radiosity there reflected upward from the garage roof and on the soffits. Seems to be difficult to align textures - like grass and roof, even driveway. Hmm. And what is that shadodagger on the left?
Even though the textures could use a lot of refinement, we get the idea of how the monticello model can be rendered in radiosity.
The site also said that this 1024 wide rendering took ten hours on a 2x2 G5. Compared to ten minutes with LightWorks. Must have had that radiosity set too high. Or too many leaves.
Dwight Atkinson
Dwight
and the set up is:
Dwight Atkinson
