Learn more
ngoldie
Not enough Scrap-Memory for Copy
The alert Not Enough Scrap-Memory for Copy just came up when I tried to copy shadows from 3D, I quit Archicad and restarted and this still came up when I tried it again?
Thanks
Naomi
Archicad 20
MacBook Pro - laptop
5 Replies 5
Is it just when copying the shadows or does the message appear if you try to copy other elements?
Does isolating an area (say half the image or even a smaller area) with the marquee still produce the error?
ngoldie
It's okay, I called the Graphisoft support and it is a bug when copying fills from a 3D window, you just have to leave the polygons as frameless.
Naomi
Archicad 20
Naomi
It must also be dependent on the complexity of the file.
I just tried with a few walls on a slab and there was no problem.
But a small house on a site mesh and I also got that error.
ngoldie
That's good to know,
Thanks Barry
Archicad 20
Confirmed: "Frameless" resolves this issue for now.
Thanks.
