Dwight,
Thanks for the reply:
-- double check that you have the built-in sun turned off.
....Internal sun is off
-- double check that there isn't a second sun object
....Just the Undersun per your book.
-- add 0.01 roughness to the wall material
....Roughness: Scale = .1 / Amplitude = .03
-- reduce the diffuse reflection parameter of wall material
....Diffuse = .75
-- don't use white
....Stucco is a cream colour
Basically, my dilemma is that reducing Diffuse causes the vertical surface colour to render as a grey mess, whilst getting the vertical colour right leaves the horizontal surfaces burned out. Would it be advisable to boost Ambient light and reduce sunlight?
Cameron Hestler, Architect
Archicad 28 / Mac Studio M4 Max - 64 GB / LG27 Monitors / 26.6 Tahoe
- been using Archicad since V4.55
