Visualization
Render your model with built-in or 3rd-party solutions
SOLVED!
Pendant Lamp 21 Not On after Render
Hi everyone.
I've tried to look for a solution to my problem online but couldn't find it.
I have used a Pendant Lamp 21 in my project but when I render an image, the lamp is always off. I have tried changing the settings to the best of my capabilities but it still does not work. The other lamps I used in the project work fine except, of course, the pendant lamp.
Does anybody have any information on the issue?
I have attached an image for caparison between the two lamps I have used.
Any help would me much appreciated.
Thanks!
1 ACCEPTED SOLUTION
Solution
mikas
You haven't accidentally turned it off, have you?
AC28, Rhino8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
2 REPLIES 2
Solution
mikas
Yes. That was it.
Thank you. You've saved me a lot of time.
