Photorendering - Floor is changing color?
I'm pretty new with Archicad 12, and im am experiencing a problem with Photorendering. I have downloaded som images of panel floor that i want tu use in a project. The problem occurs when I use photo rendering to take a "picture" of the new floor, the color changes from oak to the color from the material I`ve duplicated from.
Any tip i can check out to avoid this?
Thanks in advance:)
1 Reply 1
__archiben
check your materials settings - there are separate controls for each different visualisation engine; openGL, internal rendering, lightworks rendering . . .
make sure you also configure the lightworks settings - click 'match with internal' for the quick and dirty option and then tweak from there . . .
~/archiben
b e n _ f r o s t
