Preset Rendering Styles
Does anyone out there know of a way to define and save rendering styles, similar in the way you can define, create and save favorites?
1 Reply 1
To save them within the project you can use views. 3D views retain the 3D window and rendering settings current at the time it is saved (you can also update any view to the current 3D settings in the View Settings dialog). Transferring the settings between projects is another matter.
