‎2007-08-30
07:05 AM
‎2023-05-11
12:25 PM
Noemi Balogh
‎2007-08-30 08:48 AM
‎2007-08-31 01:43 PM
‎2007-09-01 01:01 AM
islander wrote:You can get good quality floor plan renderings using the lightworks rendering engine. As for your materials/colors....you have to set a desired/preferred texture or .lwa to go along with your material under material settings. There's much more to it than what I've mentioned, but a few trial runs should get you on the right track. Now, for the scale, there are other ways of achieving this, but if it were me, I'd import ('AC9') the rendering into plotmaker over the scaled floor plan view set and adjust the image's resolution in the image settings until it matches the size of the floor plan view set. Or a second option would be to do the adjustments in photoshop if at all possible (im sure there's a way).
I was hoping there might be a way to do it so that I get the same quality i get in Maxwell. The main concern is making sure that the final printout is to scale.
How do I get it to present each material's colour?
‎2007-09-01 01:11 AM
‎2007-09-01 10:02 AM
‎2007-09-03 03:28 AM
islander wrote:A technique I have used is to do the regular elevation as LINE DRAWING and lay your rendering underneath it. By using the RESIZE command, you can simply visually stretch the image to match the scaled line drawing.
Rendering a 3d view of an elevation give me everything I need except the correct scale. Any more ideas? I don't have cs3, but I suppose a bit of trial and error in CS2 might work.
