Problem whit ArchiCAD 13 C4D 11.5 plugin.
This is what I cee when open the C4D file converted with the new Archicad C4D plugin !?!?!? As you can cee some parts of the curtain walls are missing!?!?
3 Replies 3
The image attachment seems to be broken.
Is it working now ?
Yes. The image is visible now.
Was the curtain wall converting properly before? You could try saving as 3DS as a workaround.
