Visualization
Problem with Reflections
Hello, Does anybody else is having problems with the reflection jumping from none to a lot?
I the Pic see the material of the columns capitals,
On top reflection = none
Center Reflection = 57 Brightness
Bottom Reflection = 58 Brightness
As you can see in the range of brightness from 0 to 57 there is not reflection at all, and when I make it 58 it jumps to have to much reflection (after 58 the reflection is working gradually until 100 that is a mirror), I can't find a way to make the material less reflective than this. Does anybody know how to solve this?
PD: the material is a simple material with a color and reflection nothing super elaborated.
Yes it worked.
Thanks Tore.
It makes others materials more reflective but it works, I just have to adjust others reflections. Thanks!
