Visualization
RENDERING PROBLEM
I HAVE A SONY VAIO AND WHEN I TRY TO RENDER IT WILL GET TO A CERTAIN POINT THAN IT WILL FREEZE UP AND SHUT DOWN, THAN A BUG SPLAT REPORT WILL SHOW UP.
PLEASE HELP
1 REPLY 1
No ALL CAPS please.
I looked at your earlier 6 posts, and they are all about problems with this laptop. Your laptop has an Intel onboard graphics chip using shared memory and is not adequate for work in ArchiCAD. See:
http://www.graphisoft.com/support/ArchiCAD/system_requirements/
Should this not be related to your graphics card, you need to list a whole lot more information in your post to get help - version (presumably 12 student), and you machine specifics (which I only found by searching your other posts).
Good luck,
