PT
rm
(Rant) Artlantis crashing with multiple lights in......
Problem #1
I do fair amount of interior renderings with lighting in artlantis ( I should say, I try to anyway). To be clear, I will set 20, 30, 70 lights in a model, some down lights, some general lighting to get as close to "photo realistic" as possible (see attached image) with in the limits of the software. Artlantis allows 128 lights.....how they picked this limit I don't understand, but I am not exceeding the limit, though I could if the program would let me.
It is frustrating to no end, when I have the lighting dialogue box open and try to re-arrange my list of lights, once I have place several lights in the plan in artlantis, the program will eventually CRASH. Usually only after I have been doing two hours of work and have not saved changes.
If I am "tweaking" light settings while switching between individual lights before the preview window completely refreshes, the program will CRASH!!!!!!
It has gotten to the point where I have to save my file virtually every two "tweaks" of lighting or I am in danger of losing data. Problem with this is it takes a long time to save the file if there are alot of lights or polygons.
The program is fine with a couple of lights, but if you try to get into realistic lighting with many lights, the progam just craps out. I have written to Abvent, but they just ignore the problem......big surprise there.
By the way this problem has occured since v3.5 of arlantis.
I use a G4 933 with 1.5 gigs of RAM and a 120 gig hardrive. Its not the machines problem, it IS the software, it is very unstable when it comes to minipulating many light sources.
Problem #2
Light from general lights in artlantis passes through walls and floors.............why?????? This really screws up a rendering and forces me to set up lighting different for different views, this should not be the case. I don't know what walls are made of in France, but I'm guessing light does not pass through them.
I wish those of us on the MAC side of the fence could get our hands on a better rendering programs than artlantis. I know artlantis is relatively fast, and simple to use. But for truly photo quality renderings, in my opinion, it is not up to the task. I may have to look at electric image, learning curve is huge as I understand it. I would like radiosity rendering instead of the limits of "global illumination" (poor mans radiosity) that artlantis has.
Any software advice would be appreciated.
Thanks,
rm
Robert Mariani
MARIANI design studio, PLLC
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
14 Replies 14
rm
Meanwhile, 9 days later, still waiting to hear from you Jacques to send the files!!!!!!
Have to ask, why does it seem to take so long to hear back from Abvent on any Tech Support question.......very frustrating.
Architects Design Forum, Ltd.
RM
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
Reply to rm.
Problem #1
About Art*lantis crash when re-arranging the lights please update your Art*lantis 4.5 into 4.5.6 at:
http://www.abvent.com/us/software/artlantis/update.asp
Why Art*lantis manage only 128 light sources? We had to put a limit, do you think it's easy (as Art*lantis is today) to manipulate 128 lights sources? above all when you need to change their status, so isn't it better not to place light source as they are in the reality but simulate the reality with less light sources?
Problem #2
About the lights which pass thru the walls. This is a well known problem links due to the way Art*lantis manages the geometry and the materials. Nonetheless 2 ways to avoid that:
1- If you put lamp shadows at 100% no more pass thru wall
2- e.g. you have 2 rooms side by side, you have no light on in the scene except in one of the room your lamp has shadows at 70%, put a camera in the other room, you might see the light passing thru the wall. put a lamp in this room if the light of this other room still disturb you switch it off.
Now we are working on the future Art*lantis version which is been completly rewritten and free of "dust". So trust on us for improving our product and giving you the best rendering solution you have ever dream.
rm
Picard, Thanks for the responce - but why did it take 3 months to recieve?
Picard writes "Problem #1
http://www.abvent.com/us/software/artlantis/update.asp"
I am on v 4.5.6, have been using it since it came out. This IS NOT the solution!
Picard writes "Why Art*lantis manage only 128 light sources? We had to put a limit, do you think it's easy (as Art*lantis is today) to manipulate 128 lights sources?"
Do YOU think users want to place so many lights? Because Radiosity is absent as a feature, and Global lighting is at best, a cumbersome imitation of radiosity, we have to place many more lights than we would like to in order to simulate, as best as possible, real lighting.
Picard writes "above all when you need to change their status, so isn't it better not to place light source as they are in the reality but simulate the reality with less light sources?"
We are not dealing with magic here. Just because I "wish" for an affect,
does not mean it happens"
Picard writes " Problem #2
About the lights which pass thru the walls. This is a well known problem links due to the way Art*lantis manages the geometry and the materials. "
Thank you for admittinig this IS a PROBLEM. I'll assume since you know it is a problem Abvent is working on a proper solution!
Picard writes " Nonetheless 2 ways to avoid that:
1- If you put lamp shadows at 100% no more pass thru wall"
Picard, no shadws are 100% black, or you would not be able to see them.....shadows vary and generally are tinted by the material upon which they are cast.....setting shadows to 100% is not a good solution, and further hampers trying to achieve realistic renderings.
Picard writes "Now we are working on the future Art*lantis version which is been completly rewritten and free of "dust". So trust on us for improving our product and giving you the best rendering solution you have ever dream."
I am looking forward to it, as my clients become more aware of how realistic renderings CAN look, they expect it, and I wish to give it to them. So if you need a beta tester, I am willing to help out.
Regards,
Robert Mariani
PS. Abvent would do itself well by responding to Tech Support questions in less than 3 months, and actually answer questions sent to them directlly, so as not to have to explore these issues in a public forum. I have emailed these questions to Abvent previously, as I noted, but I have never received any responce.
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
Dear Robert,
1- If in 4.5.6 version you keep having crash problem while managing the lights I'll be glad if you could send me an .atl file getting this trouble, so I'll check it.
2- I don't know the project size you are dealing with but I'm still quite impressed that you need so much light sources, so if you don't mind I'll be glad to take a look at one of your .atl file so this way the discussion will become more concrete. (Files you could send will be for internal use only I will open you our ftp web site to upload).
3- Lights passing thru walls, such it is with Art*lantis since the beginning. This can't be fixed in the actual version. Technical choice and compromise had to be taken.
You are welcome to participate to the future betatest of the future Art*lantis version.
Please to do so confirm it to me by e-mail at:
[email protected]
Regards
Alain Picard
Abvent
rm
Dear Alain,
Thanks for your reply. Check your email, I have sent you my address. I would like to take you up on your offer to upload the file to your ftp site.
This is a large file, along with additional textures for the file. I look forward to your instructions.
Regards,
Robert Mariani
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
