Render mesh Enclosure at Arlantis
Hi all ,
I wish to render mesh Enclosure (beside Gable covered roof) at Arlantis, but it's seems like a solid wall with mesh patterns on it!! >_<.....it's render all right at "lightworks" when Alpha Channel of the mesh (PNG file) is on.
In Artlantis, the mesh Alpha Channel is on too~~ Just have no idea why the mesh wall still won't see through.
Have I missing something??
Please help!!!
Thanks
Star
14 Replies 14
Dwight
Select the image background color as the mask - not the alpha channel, and see what happens.
Dwight Atkinson
Hi Dwight,
Thank you for your reply,
where can I at Artlantis to change the image background colour as the mask??
Dwight
The arrow shows the box, to the right of the box is the color to mask [make invisible]
Alt-click the background to select the masked color.
Dwight Atkinson
Hi Dwight,
Thanks for your reply, I've just did that~ and doesn't seems to works, at first, I thought you are saying to adjust the background of the image (mesh) as mask at photoshop.
here's the example of mesh enclousure render when color to mask is on.
Dwight
Could it be .png?
Try jpeg and see.
Dwight Atkinson
Hi Dwight,
sorry for late reply, was so busy at work since last week.
Yes, I've tried Jpeg too, and not working.
star
Dwight
Too bad.
I've shown you all i can - you do need to eyedrop the color to be masked.....
Dwight Atkinson
hi Dwight,
Yes~!!! Finally,
I think I've discovered a way to sort out the "mesh Enclousure" now~!!!
steps by steps of mesh enclosure rendering (read with pic attached)
1. export the project from Archicad 3D view, save as >> Artlantis formate
2. open Artlantis, you will see my "mesh enclosure" has changed from PNG (in archicad) to Jpeg file (in Artlantis), don't really know why, dont' ask me..hehehe...
...cont....
next~~>>
select the original jpeg file "metal mesh" from material list, and delete it.
