Rendering problems with Lightworks in AC 11
Hi girls & guys!
Got a bit of a problem when trying to render a project in Lightworks. The project is rather large, with 64 houses and 5000KB. (The houses are all modules, which should make it manageable).
But AC11 either crashes or claims "not enough memory to render the project".
I've closed all unneeded layers - and for safety - deleted all the empty ones too.
I thought I had plenty of power and memory with a Dell Precision 690, Dual 3 GHz Xeon 4 GB of RAM and a Nvidia Quadro FX 4600 with 768 MB on board.
Any good ideas ? Thanks in advance.
Jan
10 Replies 10
Dwight
It is entirely possible that your model is too large to render with your system, but i suspect that it possesses a corrupted element. [Judy Tenuta: "No man will possess ME!"] It may be possible to isolate the corrupt element: cut the project in half and render. Then the other half. If both sides work alone, then perhaps your resources are inadequate. If only one side works, use your mechanic's mind to isolate and identify a bad element - possibly in the module.
There was an instance of the spanish roof tile elements making a file too large for a PC to render that was easy on my Mac but who can say why this is - when i rendered that model it only ran up to 1800 Mg
The fact that your houses are modules is irrelevant to the rendering challenge. A small file can make a big model. The rendering challenge comes from the final 3D model as it is assembled into planes in the 3D window - executed from your Archicad file. Those house modules simplify your Archicad file because they are made once and called into the model numerous times, but once they are in the 3D model, their planes place the same load on the rendering system as if they were all unique.
Dwight Atkinson
Thanks Dwight.
I will try that again, this time in smaller bits to locate the possible problem.
A nice day to you.
Jan
Jan wrote:
Hi girls & guys!
Jan
Hi again Dwight.
You were right, the file is too large to be rendered with Lightworks. In smaller bits it works allright.
But the problem is I, have to present the whole lot in photorealistic pictures. Would Artlantis Studio 2.0 be a good idea or would you use another program.
Thanks again for your advice.
Jan
Jan wrote:
Hi girls & guys!
Jan
Dwight
Artlantis 2.0: You, You, You!!!
Dwight Atkinson
I share Dwights enthousiasm
Hi Djordje.
'cause it's not a secret. So here you have a couple.
Jan
Much obliged guys. Thanks for speedy and enlightening replyes.
Very good forum.
Jan
Djordje
Let's see the rendering, if it is not a secret?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dwight
Jan wrote:
Hi again Dwight.
Too large for your computer, rather.
Dwight Atkinson
Yeah, you are absolutely right about the trees, but I would like to keep 'em.
Still thinking about the renderprogram. Will probably end up buying Artlantis in the nearest future.
'ave a nice day.
Jan
Hi again guys.
And this is the lot I wanted to render.
Jan
