Saving LightWorks Rendering Engine Settings
Having done a quick search about saving rendering settings I've found a few rather manual methods to save Sketch settings (using the text document SketchTextures.txt) but that was quite a few years ago now. I understand saving a view in the navigator might do the trick too?
I am using AC15 and am wondering if there has been an improvement on saving rendering settings in these recent versions of AC, especially with the LightWorks Rendering Engine.
Why I want this at the moment is because I want to quickly switch between a quick low res draft render and a more extensive final render for many images of the project. This involves changing the size of the render, resolution, quality options and occasionally even the background options (adding a sky behind).
Thanks for your help!
Anyone have some 2012 breakthroughs?
1 Reply 1
David Maudlin
kizamikusari:
If you are using the LightWorks engine, then the rendering settings can be saved as part of a View.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
