ananas
Sketch-Style?
Hi everyone!
Does anyone know if it's possible to achieve a sketch or pencil-style visualization that looks very similar to this one:
Any suggestions for the rendering settings?
If that's not possible within Archicad itself, do you know of any other software or AI tool where I could upload a screenshot or render, and apply a sketch-like filter to get that effect?
Thanks in advance for your help and suggestions!
If you go to the 3D Viewpoint with a 3D model generated, you can use the Document > Creative Imaging > PhotoRendering Settings menu command, which will bring up a palette, and in the palette's "Engine" field, you can select the "Sketch" option.
You will find information about its use in the Archicad Help files:
https://help.graphisoft.com/AC/28/INT/index.htm?rhcsh=1&rhnewwnd=0#t=_AC28_Help%2F140_UserInterfaceD...
