Carstenem
Surface Material - new from catalog error
Hi all
I created a container with a surface material created by myself. Followed the exact procedure as per GRAPHISOFT Website. The container is created correctly ( I did extract the container and the folder has the correct contents in there )
Now I am trying to add my new surface:
- Loaded the container in to my library , fresh ARCHICAD file for testing ( did a reset all )
- clicked new in surface window
- new form catalog
- choose my catalog ( container ) created
- choose my surface material
- click ok
Then I get this error message: Failed to create surface.
I have attached a screen shot.
Any help would be appreciated.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Carstenem
Got it ! I did have a suspicion and I was right. I am testing the new Corona plug in at the moment. The Corona plug in seems to conflict when saving out a surface material you want to add to your container.
I did unistal Corona and went through the whole process again. This time no problem with loading a new surface from my own created container .lcf file.
You only find out btw when you do what I wanted to do. The saving out works perfectly even with Corona installed but somehow when creating the container .ifc file the Corona plugin is creating a conflict.
I will get them at Corona feedback of this, as they need to fix this problem.
Cheers Carsten
Carsten
www.asmtechbase.com
