Visualization
Render your model with built-in or 3rd-party solutions
Textures...how to
This is my first project in archicad, I would appreciate if someone would take a look at it and tell me what can I do to improve it. I used original rendering provided with archicad. Still the ceiling looks a bit to dark, and I don't quite understand working with created textures(not the existing ones, those are quite easy). For example, the stone part on the walls is not what I originally wanted, but it was the best I could do. Stone was supposed to be much smaller, in mosaic kind of style. Thanks.
15 REPLIES 15
David Maudlin
Incursori:
In the Materials dialog box, Internal Engine > Textures, set the size of the texture as desired, then switch to Lightworks Rendering Engine > Textures and click on the "Match with Internal Engine" button. This is the easiest way to set the texture size.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks a lot.
Dwight
In the"LightWorks in Archicad" book, it addresses using general light to actually illuminate the scene and use your lamps as low powered "props."
No light is white - make light yellow or golden.
Try to compose a scene in this room that captivates the eye and tell us something about the space.
Your surfaces are too slick - add roughness.
Dwight Atkinson
Dwight,
Do you have to change the settings of all your materials to get the effect you want first or does the rendering engine do it?
Rick
Dwight
In this case, any material with glare on it is too shiny and doesn't interact properly with light.
All materials need individual assignment of even 1,1,1,1 in the displacement Roughness shader
Dwight Atkinson
Totally lost me on that. Where is that setting?
Rick
Dwight
This would be in the LightWorks Material Dialog.
Dwight Atkinson
This?
Dwight
If you stumble around in there long enough you'll find the Displacement Class Shader "rough"
This is why i wrote the book, eh?
Dwight Atkinson
