The Ultimate Image Viewing Technique
Create a huge image with at least 50,000,000 pixels, save in Flat Tiff format - no layers - (other formats may work also). Upload to GigaPan.org
Allows easy viewing, pan, zoom.
Here is one example created with ArchiCAD and Cinema4D
http://share.gigapan.org/viewGigapanFullscreen.php?id=7498
Mark Burginger
3 Replies 3
Wokka
Mark,
Very cool!
Very Google-Earth-ish.
On a side note, C4D, which library of trees are you been using?
Cheers
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
Tree entourage by xFrog.
http://www.xfrogdownloads.com/greenwebNew/products/productStart.htm
Look under PRODUCTS - The stand alone plants and trees
The Trees and Plants are in C4D format, no plug-in necessary.
See for yourself, here is a link to a demo tree, Merry Christmas.
http://www.maxon.net/pages/dyn_files/dyn_htx/htx/827/00827_00827.html
xFrog itself is an application that allows you to generate your own plants.
Wokka
Ahh, thought I'd seen them before!
Thanks.
Sorry this is so off topic. Last question.....
Do you need XFrog the program or is there a free plugin to import the models.
Lumion 12.5/2023
D5 Render
