Copy camera to different file?
Is there a way to set a view in one file and copy that to another? I have 3 different variations of a design on 3 different files and need to render them so that they are all the same exact view for comparisons. Any ideas?
4 Replies 4
Set up the views you want in a separate file and hotlink the alternates into it. There are several ways to do this but the simplest is just to redirect the hotlink to each file in turn and republish the views.
Where can I find an example/detail on how to do this? Ive never used hotlinks or anything before.
Thanks!
You can start with the Reference Guide in the Help menu.
Ah thats easy! Very cool! I wish I had known about this a long time ago!! Thanks so much!
