Top view in perspective?
Is it possible to set top view in perspective, so that the viewpoint and the target are in the same vertical position (camera settings: distance field = 0)?
Thanx, chipo
Dwight
No. Not perfectly vertical:
The closest is:
Camera Z = 50
Target Z = 0
Distance = 13/32"
This gets you looking at your feet if you can see over your belly.
I put Archicad's hairy belly object in views like this to add realism.
Dwight Atkinson
Thomas Holm
Don't need that. Got my own!
