Integrated
Use ArchiCAD + the new LightWorks rendering engine
Alternative (will there be a new version for AC9?): AV_Works, which is the rendering of Art*lantis integrated into ArchiCAD.
+ you allready have it in ArchiCAD, no conversion
- you can only render the things you can model in ArchiCAD
Easy & fast
Art*lantis. Wait for version 5 if you want radiosity.
+ price, speed, ease-of-use
- rendering quality is limited
More involved
Cinema4D using the connection plugin, so the model is transferred automatically. This is a full new program, so you need to learn about it to get good results. That said, once you can work with it, the sky is the limit.
+ reasonable price
- a full new program to learn
If you do this fulltime
Any of the full 3D-animation software programs: Cinema4D (from $500), 3ds max (from $3500), VIZ (from $2000), Lightwave (from $1500) , Maya (from $2000), Softimage|XSI (from $495), ... and then you still have options on the rendering engine: integrated, plugins (VRay, Brazil, Mental Ray), external (Renderman)
+ power & quality, animation, modelling... everything is possible with much control
- price, learning curve, you need to convert your scenes
Freeware & you like programming
Radiance or POV-Ray or BMRT or Lightflow or Jafray or many, many other standalone rendering engines.
+ free & sometimes very good
- complexity, you need to convert your scenes
Archicad-user since 1998
my Archicad Book
