Visualization
Wide angle
Is there a way to make renderings with a wider angle to see more of the space?
Yes you can :
Change view cone : View > 3D View Mode > 3D Projection Settings
thanks
you can also make your image wider in the rendersettings. This way you get a panoramic kind of picture but you don't have the angular distortion on the sides of your picture
