area light problem
hi. i have a problem with area light. I cant controll it at all no mater the setting that i give the result is almost the same, over burned surfaces near the light source. how can i create a small point light.
4 Replies 4
Erika Epstein
Syber,
To answer, could you please give us some more information?
Which progam?
Archicad 9?
Lightworks?,
which lamp?
etc.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
ac9
lightworks
point light has the problem as some other lamps the one is a metalic celining lamp with cord (Icant remember its name)
Dwight
-- a general light source at intensity 33 and falloff 2 is a good area enhancer. (LightWorks in ArchiCAD - page 51-57)
-- a large light cone down is used to illluminate an entire room (LightWorks in ArchiCAD - page 58-69)
-- a light that can approach a surface closely without glare is the Wall light indirect. (LightWorks in ArchiCAD - page 70-73)
Dwight Atkinson
Dwight
-- also: the actual light fixture lamps have not all been updated to emanate soft light - use a light source inside a fixture and control them separately.
Dwight Atkinson
