Visualization
camera View
hi guys,
A new user of Archicad and the experience has been tremendously awesome so far....its much faster designing and drafting plans here though.
Pls i need assistance in designing roofs...especially when the roof is a bit complicated. I understand that there are free add-ons someplace where i can download for complex roofing. In addition, could the walls of my buildings look thicker just like how the polylines/lineweights look in AutoCAD? Before i forget how can you render a camera view only...whenever i render in the lightworks, the building looks so far away.
Thanks so much.
Ters
Think real, think big.....THINK POSITIVE!
good
Dwight
Roof
Try first with the polyroof tool. See attached. This will place a roof bounded by your contiguous walls. It uses the magic wand to locate the perimeter - It follows around and makes a great job.
Walls
You must specify the actual wall thickness in the Wall tool. Each pen has a controllable thickness. But on-screen you can draw in real thickness or hairline.
Render
Use camera tool to place a camera on the plan in a reasonable place relative to your building. SELECT the camera. F3 for a view.
Every one of your questions indicates that you should thoroughly study the documentation and have a friend show you a few things....
Dwight Atkinson
