Visualization
construction simulation in 9
I am trying to run a construction simulation in 9 and can't find any information on the plugin..can anyone point me in the right direction.
1 REPLY 1
in the archicad help, search for "construction simulation" and the first one is a little "mini-manual"
I did some animations, and figured out (on the windows version) some puzzles:
- don't use the custom object in animation, the output will flicker between frames-use the date and custom text only.
- only quictime format worked for me, the wmw format didn't
some unfortunate limitations though:
-you can't do smooth phase transitions in animation: since schedule items can't overlap if some elements are linked to both of them, between -say- BUILD and FREEZE the final material will flash through, and at the end of the
TEMPORARY and DEMOLISH it will disappear-no matter what color it should be in the next phase
For example: foundation elements should be rendered in different colors representing: excavation-formwork-reinforcement-pour-cure phases.
-the one day/frame is to restrictive
-the one day granularity in schedule is to restrictive
-it would be good to have multiple BUILD-like schedule items, like concrete work shouldn't look the same as framing or finish work
-text export/import should also contain the linked objects in some way, so importing a new schedule shouldn't necessarily throw away all the linked objects.
