2014-06-06
03:59 AM
2023-05-11
01:17 PM
Noemi Balogh
2014-06-06 01:58 PM
Dave wrote:You cannot change the numbers (sequence). The easiest solution could be to create a screen shot of the current path, place it on the plan (use the Figure Tool), then use this as a guide to create a new path in the correct order. If you want to play with reordering the current path, a new camera will be placed after the last selected camera.
I built a camera path but i copied some of the camaras as i went.
now the sequence doesn't start where i intended.
How do I (can I) change the camera numbers?
2014-06-06 05:23 PM
2014-06-07 01:46 PM
Dave wrote:The Camera Tool has not changed in AC17. One trick with the Camera Tool is to use the Pen assignment for Cameras to differentiate Stories in the same Path; so the Cameras on Story 1 are assigned one color, Story 2 another color, etc.
The difficulty with looking at the path is that all cameras show up from all stories and i'm in small spaces across several stories so i had to be sure i was selecting the right camera based on elevation. Blinding.
I assume this is easier in newer versions of AC or in add-ons.
Dave wrote:Actually, there is: create a View for the first Camera, open the 3D Window of this View, change the values for the 3D Window and PhotoRendering Settings as desired, select the View in the Navigator, click the Settings... button in the Navigator, go to the 3D Only panel, click the Redefine Image Settings with Current check box.
Unfortunately i can't get my sun settings to stick for a fly through rendering anyway per my next topic.... and i don't understand why there is no way to save 'favorites' settings for rendering.
2014-06-07 03:36 PM
