‎2009-08-24
09:24 PM
‎2023-05-11
03:01 PM
Noemi Balogh
‎2009-08-24 11:19 PM
‎2009-08-24 11:35 PM
‎2009-08-25 12:12 AM
‎2009-08-25 01:17 AM
goliveira wrote:You could try OBJECTiVE. It includes profiling tools that can easily create the lamp shape. I created the attached image by lathing (sweeping) two profiles (one for the outer skin and another for the inner). Objects created by this add-on have a parameter to control the material direction, so an image can be aligned correctly.
How i can put the bottom image inside of the semi circle ?
‎2009-08-25 01:46 AM
‎2009-08-25 01:53 AM
‎2009-08-25 03:57 AM
goliveira wrote:Refer to the attached image:
now im trying using Ralph's Objective, is exactly what i want, but i don't know how it works... Ralph can u give me more tips how you do that?
‎2009-08-25 11:21 AM
‎2009-08-25 11:34 AM
goliveira wrote:Make sure the option to 'Use Object's Materials' is checked (see attached image). Also, you may want to put a lamp inside it if you want the fitting to appear lit.
i did all steps as u said, but when i select the material (any material) for inner or outer shape and press ok, the shape don't change still dark.
